621 - 640 of 654 Posts
Discussion Starter #623
got a smaller case then what comes with drone. to be more compact.
you can use your phone to be really compact.
sometime I use my tablet because you can see better what your doing...
If using tablet you will need to get the mount adaptor and longer data cable
How does it work in the frigid cold, battery life and moving piece , etc ..
Discussion Starter #626
Worked fine. Batt just wont last as long.
Normally 30min per batt
Sent from my SM-G965W using Tapatalk
Discussion Starter #627
Its hard to find a big enough gopro case to hold everything
gone through 3 bags
this is the best so far from amazon
https://www.amazon.ca/gp/product/B071WPPTZ8/
Upper and lower compartments and also has compartment for tablet
Discussion Starter #628
Last but not least is safely transferring all your video and pics from all your trips
I use Hedge to transfer all my files to all my hard drives. https://hedge.video/
It makes sure all the files are transfered with no errors and fast transfer
You dont want to find out later that some of your files are corrupted :wall:
I transfer my gopro videos every trip and you can trasfer to 2 hard drives at same time like i do. If 1 drive fails i still have another one :thumbsup:
Discussion Starter #633
Remove driver bearing to check. Bearing spins nice and smooth. Use pic to pop seal off. I repack from top leaving bottom untill last. Try to pack the grease in without turning the bearing. If any moisture got in there it will come out the bottom as u pack the grease in above. use paper towel to suck any moisture at bottom. spin the bearing after to spread the grease around. put seal back on. Good for another year
I use this opportunity to see and check the bearing forsure. You could get the grease plate kit from rick which i had on my last sled. For me you would never know if the bearing is going bad or any crap got in there. all your doing is pumping grease in and hope all is good. Im just picky on my sled
Do you have a part number for the NTN bearings in the pic above? What are the larger 2 bearings for?
Discussion Starter #636
How has the 2 inch track held up? How bad is it to run on hard pack trails?
Sent from my iPad using Tapatalk
Been using the 2" for the last 4yrs no problem at all. No broken lugs or anything. I dont use scratchers either
I wouldnt get anything less then 2" track. Ive had 1.25, 1.6, 1.75. never again. they suck for off trail
Discussion Starter #637
Changed all track wheel bearings. They generally last 2 seasons. Doing now then good for another 2 yrs. Upper 2 wheels use the bigger bearing. All the other 12 wheels use the 6004 bearing. I dont wait till something breaks before fixing. I want to ride not sit on the side of the trail with the track all screwed up
Discussion Starter #640
FREE Mod !!
Been wanting to do this mod for a while. Tip the back of the ski. For when in deep snow and you have to backup for some reason the skis start to dig in.
Put back of ski in vis and heat boths side evenly. Dont need to torch it to much. It will start to bend..
