21 - 40 of 645 Posts
Discussion Starter #23
if anyone has the dash off you should double check you dont need the fuel pump changed.
You can see it with a flashlight on top of the fuel pump.
If it has a 8 then it was supposed to be changed. take it to your dealer.
mine has a 10 :thumbsup:
Discussion Starter #29
bags dont come installed from factory.
good then i dont have to remove it.
installed the plastic grate under bag to keep any moisture buildup and inside bag stays dry
you dont even know its under there :buttrock:
Discussion Starter #31
installed rubber grease nipple covers on all the grease nipples
removed spark plugs and opened the gap to .027 and also the spare plugs for belt holder
plugs are always less then .027 new
Discussion Starter #32
Set rear spring to middle stiffness to try on these new ones. not sure if they changed anything in the last 2 yrs
my 2017 sled i always used highest setting and it worked good.
Discussion Starter #34
get one of these longer bolts at dealer to make it much easier to install this 1 bolt through bumper and skid. They have lots laying around from other jobs
Drill both support holes a bit bigger. different sleds can be tight and hard to install. this will make it easy to install no matter what
Discussion Starter #36
get the new support inside installed. leave bolts loose till you get all bolts in place
drill the skid plate hole to 5/16 ( the second hole down from front of the plate)
thats the hole for the longer bolt
bigger hole to get to the bumper support inside compartment
dont forget to drill the stock belly pan hole.
so long bolt goes through the bumper, skidplate, belly pan. Thats why its much easier with the longer bolt
hold the skid up and slip the bumper in place at same time. get the front bolt through bumper,skid,belly pan,support inside
Discussion Starter #37
tighten the bumper bolts, support bolts, 2 skid bolts
the 2 tight skid bolts will hold the skidplate up nice
the 5 self tappers are the last thing to do
push plate up and should be straight at the end
hold and screw the first 2 screws tight. I always finish the screws by hand so you dont strip the holes.
the last 3 screws install them at a little slight angle forward. tip of screw angled towards the front of sled. Theres a bolt boss inside you will hit if you just do them straight up.
