1 - 8 of 8 Posts
is this what you are using for de-icer?
cat dealer did not have cat brand so i bought this before i head north!
Administrator
YES ... make sure you run with the isopropyl in the RED bottle. Do NOT, repeat ... DO NOT ... use the HEET in the yellow bottle.
Administrator
Originally posted by cmscat50@Jan 20 2003, 05:29 PM
Why not use heet???????  I use it all the time and have for years.
Cat S.  :huh:
There was a discussion about this a while back. The yellow bottle of Heet is designed for cars, trucks, etc. Not for 2-stroke engines. Here's what I was able to pull from that old discussion:
Do not use methanol fuel drier!!!!!!!!!!!!!!!!!!!!!!!!
Straight fron performance manual.
Engine damage caused by the use of methanol blended gas would be the same as operating the engine on fuel with a very lean mixture.Piston skirt scuffing,seizure,and bearing failures caused by lack of lubrication may result.
HEET-yellow bottle uses methanol
WOW,
Thanks LobanteF7. I guess I'll know from now on. Good thing I have 100 octane in the sno pro right now. :p :p :p
Cat S.
1 - 8 of 8 Posts
