Banned
Yes.
The instructions list the Polaris part # needed.
I went to dealer with # in hand, he gave me battery, I came back to find the one given to me was too tall also. I called to report this and they said "Well, the battery you have is what all other Polaris's use. It will be fine. I then asked for them to cross-reference the part# given in instructions and they said "It should be the same I said."
Unbelieveable what I go thru everytime I deal with my local parts departments.
Anyway - I kept the battery given (too tall one) and since I had not installed foam strip on top piece of battery holder yet, I noticed that by bending the left tab (one that has screw hole in it) slightly I could get it over the stud. Note: I had already installed the two lower foam strips and did not take these off. I'm sure there would be more room if I removed these.
It's in their tight and should have no problems.
If I do, I swear I am going to lose it.
Trips to any of my 'local' dealers are minimum of 30 minutes each way and usually agonizing when I get there.
If you need the Polaris part# let me know, I'll dig out the instruction book.
Banned
I lost my mind trying to find the two holes for the starter bracket. There weren't any. Doh ! :eek:oh4:
BTW: Now is a good time to fix the coolant hose rubbing against the pipe bracket up front.
I had some NAPA hydraulic hose protectors that use zip ties. Pretty cool items - I use them for every hose rubbing situation. They are Caterpillar yellow but I don't care - they work better than old split hoses that I used to use.
