1 - 7 of 7 Posts
for u people who say for the front springs u turned them all the way loose then tight so thet dont rattle i got a ? for u i did this and i didnt even go 20 mi and both spring retainers fell off luckily i didnt like the ride and i went to tighten up the springs and i noticed they fell off otherwise i could did alittle damage.
has happened to anyone else
You loosened them too much :eek: Be careful!!! Make sure the shocks and A-arm are free of any snow or ice while adjusting them.
You have to adjust them with the front of sled jacked up, no pressure on skis.
Originally posted by ditchrider+Feb 9 2003, 12:31 PM-->
<!--QuoteBegin-zekester
@Feb 9 2003, 07:18 AM
that is what i did[/b]
if you adjusted them properly with the front of the sled elevated, there is no way that the spring retainers could have fell out.
Again, lift the front of sled so skis are off the ground. Back off IFS springs until they are loose and rattle.. Then retighten the spring until they are just snug and don't rattle.
No way the retainers can fall out then.
Why do you loosen the front springs, i have mine on the tighter half.... :huh:
I noticed right away that lowering the front end by backing off the front springs reduced body roll and the "tippy" feeling that the stock suspension setup had. It just seems to handle better with them set low as possible.
1 - 7 of 7 Posts
