1 - 20 of 21 Posts
2021 VR1 850, 18 Tiger 8000, 17 RS 6000, 16 ZR 6000, 12 F1100T, 11 EXT 800, 09 Z1 Turbo, 05 ZR 900
What am I missing here?
I ordered Ibexx scratchers before my sled came in and then read they wouldn't work, with that I ordered the SPI scratchers and the One Rig Mount, being that I really like the Ibexx I had to see if they would work with the One Rig, I marked the plate where the hole would be drilled and actually have the option of mounting the Ibexx directly to the backing plate (as seen in the last pic) and then using a portion of the outside plate to secure the tail end of the backing plate, this would give the Ibexx more bite on the rail lip to resist the rotational force........ Thoughts please.
Also what is the thread size of the spring hooks folks are screwing into the torsion spring mounts?
Thanks
Thanks
View attachment 2115672 View attachment 2115673 View attachment 2115674
Are you sure your torsion spring is going to clear when suspension is collapsing?
Thanks
Check this thread out and the mounts I came up with.https://www.hardcoresledder.com/threads/ibexx-ice-scratchers.1875685/unread
Discussion Starter #4
I'm not, that's why I'm asking what an I missing?
For some reason that link isn't taking me to your pics, could you post another link, thanks!!
leave out the /unread part and you're good
Discussion Starter #6
Here's a pic from that thread, it's a 137 Matyrx skid. If the SPI clears I'm thinking the Ibexx will clear?
2115699
Have someone push down on rear bumper and watch spring to see how close it comes. You could take spring tension off and push down to see if you don’t have help. Pull spring out of guide in front to relieve tension and the take it off the adjuster in rear. Put spring back in slider and push suspension down and see how close it is. Probably will need rear of sled off ground to get springs off adjusters.
To be completely sure of clearance, you need to compress both the front torque arm and the rear torque arm. You'll need blocks under the front of the track and probably under the rear idler, as well. As the front torque arm compresses, it moves the rail towards the rear.
I found it best, to take 1 torsion spring off the adjuster, to reduce spring affect, and then measure off the other side torsion spring that is still hooked up on the low adjuster block, setting. The torsion spring may move forward/or back. and throw off your measurement, when the spring is not under tension.
Discussion Starter #10
Thanks for the info gentlemen, I think for simplicity right now I'm just going to go with the SPI setup for now.
Do you guys know what diameter hook bolts I should use?
Whatever you use, if it goes on the rail, you need to watch where you put it.
I believe the mounting bolt for the spring slider is 8mm which is very close to 5/16.
Discussion Starter #13
I'm going to mount the SPI scratchers where the One Rig holes are, no sense in reinventing the wheel with the Ibexx especially after seeing that disaster the Canadian kid posted with the spring harpooning the heat exchanger.
Thanks (y)
2021 Polaris VR1 650
Thats what I decided to do, in the off season I will spend some time and make the ibexx work.
  • Like
Reactions: vince
Discussion Starter #15
What size spring hook did you install, and did you use the existing threads or did you tap it?
5/16, bought it at ACE hardware along with the tap.
  • Like
Reactions: vince
Discussion Starter #17
2021 SB Assault 850 - Proud member of Southern Tug Hill Sno-Riders
Thanks (y)
That part freaks me out actually. I had the one rig keeper plate machined for the SLP scratchers but I dont think I am outting any of it on from what that kid posted. Sure dont want that. Maybe I will mount on the skis.
Are you talking about Straightline Performance scratchers (similar to the Duraflex Cable scratchers)?
SLP is normally the acronym of Starting Line Products. They do sell a kind of old school single spring with a short arm and a long arm, which usually requires removal of the outside front bogie wheel:
SLP Single coil rail scratcher
My pictures posted some time ago show exactly how much room you need for the SBA 146 rail, if you mount forward of the torsion spring slider. If you mount behind it, like SledTuner360, no worries. You just need to pay attention.
Take another look. Remember this picture is from a Matryx SBA 146, equipped with the IGX rear suspension.
The measurements and placement is different for a Matryx INDY with the Pro-CC suspension.
Post with Matryx SBA 146 fully collapsed picture
IF you have a plate machined for the forward hole in the rail, that I have the scratcher spring over, you just need to get some holes drilled and get it on. I plan on putting a J bolt type hook for the scratcher into the mounting post for the slider block, like many others have done.
Yes straightline performance. Not starting line. They are thicker. They mic up like .640. Much less flexible.
1 - 20 of 21 Posts
