1 - 1 of 1 Posts
Hello can you guys help i need an intro paragraph like 4 sentences and a closing 4 also please help Platinum
Platinum is a rare metal, it looks similar to silver or white gold. Platinum is a very heavy metal. Platinum is about 60% heavier than 14k gold. Platinum is more expensive than gold, why you ask well that is because platinum is harder to find that gold, platinum is also a hard metal to mine and also it requires a very high melting point. The most places that platinum is most commonly found are Transvaal, South Africa, The Ural Mountains, Russia, and Alaska. It can be found in streams, rivers, behind trees, and also hill sides. Platinum was found in 1803, in Egypt. Platinum is used in lots of different jewelry, like Watches, Rings, Bracelets, necklaces and many others. Platinum would be too soft if it was not mixed with iridium. When they are mixed it is an extremely hard metal. Platinum usually costs around $60 per gram so it is not cheap. Platinum is not easily stretchable because of its dense metal. Platinum has been on a rise for popularity in the last 50 years. Did you know that a 6 inch cube of platinum of weighs 165 LBS, also one gram of platinum can stretch out to more than a mile in length.
1 - 1 of 1 Posts
