I have a 1999 zl 500 efi I bought it with some mods on it but does not run the way it should. Some mods are a D&D trail chip a D&D stock clutch and some kind of can. I have all the stock stuff I was thinking of putting it all back in but I figured I would try you guys first any help would be appreciated. I also replaced the flywheel & stator does the sled need 2 be timed thanks again.
It wont run anywhere near as well as a F7. Its a 500. HP stock low 90s
torque high 60s. We have a stock ZR500 we still use. On the trail I run
it WFO and my wife passes me any time the trail gets straight for long.
Banned
I'M sorry I don't know why I put clutch in there. The sled just don't seem right is there anything that I could check or do to help get some power back from the sled
IT's hard to really say without more info, that sled should engage around 5000RPM and than turn 8500 and rev out to about 8800RPM, if it in runnning around these rpm's it's a start. Some guys don't like the high engagement and lower it killing the bottom end, and probably messing up the top also.
