Hello i want to replace my motor mounts i removed my motor yesterday and can't get the front mounts off. What do you have to do to remove them thanks The Big Dog.
There is a special socket for the mounts. There are 3 steel tabs that the socket tries to grab then you can turn the mount. Using it sucks, so I just take a punch or screwdriver and hit on the tabs and it usually breaks the mounts loose for me.
channel locks work better. some are just threaded into the bulkhead, others have a nut under the bulkhead rail. when puting the new ones in, try not to grab the rubber with the pliers, keep them on the steel.
None of them were broke but sence the motors out i'll upgrade my motor mounts Thinking about SLPs new uratain 85 duro mounts.
