I would like to charge a battery for gps and a after market tach... should i use the red wire from the voltage reg?????
Please help!
Is there a brown and yellow wire connection in the headlight harness that you are not using? That is the one most people use for the electric shield connection. It could be used to power the GPS unit but I don't know how much it would charge it. Is the GPS unit 12 volts? If not you will need to get the voltage reduced.
If you don't already have a battery what do they do with the red wire? Is it in use or does it just have a cap or something over it?
It's only a single diode so it's a half wave rectified voltage coming out. It should be able to charge a automotive type of battery. Not sure if it would charge a nicad type though.
