I have a 2003 F7 is having massive clutch problems. I get, at best, 40 miles per belt. The sled has 330 mile and I have gone through 9 belts. It has been in the shop three time already this year. The first time I took it into the shop they replaced the primary clutch, due to the fact that it had overheated and the bering had seized up. The clutch was getting so hot that the metel turned blue. On then new cluch that was recently installed the same problem occured. Now the new clutch is froze shut and in the shop again. Has this happened to anyone else? Or is just my bad luck. Any ideas or information regarding this problem would be greatly appreciated.
Thank you,
Thad .... Anchorage, Alaska
Thank you,
