Guys,
I need to replace the oil pump spring on my 99XC 700. Parts fische does not show the spring. Seems like to get the spring only, I will have to buy a whole new pump!
Anyone have any thoughts?
Hey Fire Chicken,
I would try two things:
See if you can get a spring or pump assembly from a junkard or eBay. Or perhaps a swap meet coming up in yor area?
OR
Make one out of some spring or "piano" wire of the same diameter. I think you could get the wire from McMaster-Carr or Fastenal. Just make some test winds around various drill diameters to get the proper unwound diameter and bend the ends to fit.
Good Luck!
Steve
:ylsuper:
polaris has a replacement spring but it says it only fits 1985-94 maybe you can modify it to work on yours. Part #3083123 which has been superceded to #3087210 retails for $8.31 good luck.
