Its much easier to take apart than it is to put back together. I have it off now and don't know how to set the spring to pull it back in. It would be a cuople days at the dealer so I did it my self with mountain climbing rope. Some help would be greatly appreciated. thanx
dealer just put recoil update in and no rope, guess what happened to me?
wind rope around plastic housing (leave a 1' or so out
coil up spring and lay i in the housing (dont wind, just so its laying neatly in the bottom of the housing)
lay plastic piece down on top of spring (little hook will fit inside cutout area) be patient it takes a little.
turn plastic piececounter clockwise (you are putting the "recoil" action on the spring now. Just leave the chunk of rope out and it will squeeze between the houseing and the plastic recoil.
Check to make sure you can get full extension on the rope. If you wrap the spring too tight the spring will wind tight, before you get full extension .
It takes a little, but its easy.
Pat
Discussion Starter #5
THE PROBLEM WAS THAT THE SRRING GOT ALL MESSED UP WHEN THE ROPE BROKE. AFTER I FIXED THE SPRING IT WENT TOGRTHER QUICK. THANKS FOR THE HELP
