1 - 7 of 7 Posts
HCS We're Watching You !!
I am putting new grips on my sled and i just took a razor knife to the old ones like you would for a golf club. But i had no idea there was this tape underneath with silver lines on it. I'm assuming its for the heated grips. I think i sliced through the tape on both sides. Do i have to get new tape or what ? or is the heated grips still fine ?
The silver lines in the tape are the actual heating elements for the handwarmers. After cutting through these you'll need to make a trip to your local dealer & buy new ones, This happened on one of my previous Polaris sleds, so I'm talking from experience here. :banghead:
i pinched one of mine when instlling hand gaurds,i tried to sauter it,but no luck its impossible,you will have to buy new ones.
Doesn't play well with other
I have a brand new set of OEM AC warmers if any are interested, there NOT 3 wire like the Fcats use there the 2 wire type that are used on the 440 racers. They will work just fine on the Fcat but you will not have 3 heat settings just 2.
They are BNIB.
Flash and Flare
1 - 7 of 7 Posts
