1 - 20 of 43 Posts
I'm curious what you're running for an exhaust setup, gearing, clutching, jetting, and if you're using the stock air box assembly. See my reply to this thread for my information. http://www.hardcoresledder.com/forums/inde...howtopic=194492
Just trying to gauge if I'm on track. I know with all the custom details on each sled, it will be difficult to compare setups but non-the-less, I can at least ask what you're running. :)
Eric, i'm surprized at how low your jets are. Who's 660 are you running, what is the compression at? Last year, I ran a Carl's 660 in my Pro XR 136" with SLP twins. I ran 460/470 for jets with a tempaflow. I ran 22-40 gearing, almond/red, 10-62 weights and I ran a button secondary. This year i'm dropping the 660 into an IQ with a 136". I'm using the stock airbox, I cut out all the vents in the hood and adding vents to the sides and shock towers. I'm going to try a set of SLP race pipes. Im' going to try and run the same gearing and clutching as last year. I have Team secondary to try out this year too, i'll play around with that once I get it all dailed in.
It's a hand built 660, not a kit. I don't know the compression, but it doesn't much matter either way. The 350 main jets are working out great so far. I rode in about 20 degree weather today. You'll have to jet down considerably with the IQ airbox. I'd expect you'll be using 370's at a bare minimum. Don't be scared to jet down. Let me know your results. I'm still working on clutching, but it is getting very, very close.
im running a carls cycle 660 in a 600 ves with twins in a proxr. im running 10-62 weights, pink primary and i dont remember the secondary, i have it all written down i have to go look. im thinking im not quite getting full shift though, i have 23/40 gears and im only pulling around 90, according the MPH calculator i should be running 100. i never go that fast but it would be nice to get full shift and gear down to run 85 to 90
this was my setup in my pro x with a hanson racing 660 single pipe with slp silencer, slp airbox mod and boysen rad valve reeds.
Polaris 10-64 weights, Polaris almond/red primary Team 66/44.46 helix with red/black Polaris secondary and 3 delrin washers.
Main jets 440
Pilot jets 40
Needles 9dfh1-60-2
Fuel screw at 1.5 turns
22 top and a 43 bottom for gears with a 1.5 tall 136 track she would run 95mph on my gps.
hey anyone know where i can get the list of polaris spring color to what weight they are, i used to have the link but its not in my favorites anymore for some reason.
hey anyone know where i can get the list of polaris spring color to what weight they are, i used to have the link but its not in my favorites anymore for some reason.[/b]
Is this what you are after???
[attachment=360161:scan0001...1_x_608_.jpg]
[attachment=360162:scan0002..._x_1091_.jpg]
[attachment=360163:scan0003...0_x_967_.jpg]
[attachment=360163:scan0003...0_x_967_.jpg][/b]
yep that it, thanks a lot man, the pink spring i got has got to be an epi then and not a polaris, i can remember where i got it from. thanks for the help
[attachment=360174:Spring_chart.xls]
My 660HO kit from carls, i had my carbs bored and here is the jetting they set it at for 0-3000
440 mains, vm22/210 #55 jet pilot, and air jet pilot .09
Recommed 66/44 secondary, they also say to try 70/46 - 68/46
Sounds like almond primary or almond/red (i'm going to consult with AKIQ when he gets time)
i'm going to try 10-64's
Mine is a 136 with 1.5 track. SLP 600HO pipe
Do you have any time on this setup yet, or is it new this year? I've heard 440 mains, but for the IQ, Pro-X or XC chassis'. I've read that the IQr chassis 660's like alot smaller mains...like 350-370's.
well this year this is what im runing now
10-64
almond primary spring
almond red secondary spring
440 twin trek helix, they are 66/46 i think got to go look
jets im running 520 with twins, reeds, pods, dial a jet now, with a 93 min head
1 - 20 of 43 Posts
