1 - 7 of 7 Posts
Hi Greg, I just have a quick ?
The wire that runs from the frontmost recoil bolt to the frame just ahead of the recoil, what is it's purpose?
I saw mine was broke off at the eye on the recoil end today, never noticed anything wrong but what symptoms would show on the sled if any?
Thanks for your time.
S
Guest
They had a problem with grounding the 1998? ZR440 snopro , it really affected the performance of the sled. and took a lot of pissin around to figure out what the problem was. Fix it!
Discussion Starter #4
I did fix it, just wondering what it's purpose was/is???
Discussion Starter #6
Boy does that look familiar. Maybe because that side of the motor moves twice as much as the clutch side when it vibrates at idle? :unsure:
S
Guest
grounding your motor and electrical system is what is does. Kind of like the - on a battery, it should be one of many grounds.
1 - 7 of 7 Posts
