Where would you take some weight off from notched big dogs. could you lay them on thier side on a magnetic belt sander ??
Where would you take some weight off from notched big dogs. could you lay them on thier side on a magnetic belt sander ??[/b]
If you are good with a minny grinder grind the side of the weight equally I have used belt sander but the grinder is faster. Make shure you dip them in water so they dont get to hot.
Best to remove the weight from each side equally untill you get it where you want,,I would stick to the belt sander, grinder can remove to much weight to quickly and gouge the sides.....R2R
Take it off the sides for sure, unless you are noticing problems with shift pattern (ie, not getting max rpms). In that case you can take weight off the underside of the tip. Definitely use a belt sander and get yourself a good gram scale, given that clutch will spin at 8grand, if the 3 are out of balance could do some damage to the crank, bearings, etc.
