2003 f7 snopro , has a inch and a half track on it was 13/4 but i trimmed it down running 22 top and 40 bottom gears getting only 95 mph on GPS what can i run for more speed?
Discussion Starter · #2 ·
turning 8000 with 66 gram weights. Whats the best way to drop a couple hundred rpm?
turning 8000 with 66 gram weights. Whats the best way to drop a couple hundred rpm?[/b]
Add more primary weight. You could try loosening secondary a hole. What springs are you running? What about helix. These can change rpm as well.
Are you getting full shift out when you are topped at 95 mph?
Are you getting full shift out when you are topped at 95 mph?[/b]
Secondary is a 55/53 helix with a red spring with white dashs on the spring
Primary is orange spring with white dashs
HELP
lol
Run the stock 22-41 gears first off.
Second you probably need 2 more grams in the primary. Before you swap weights make sure the bushings in the current weights are ok. They could be binding.
