1 - 9 of 9 Posts
DOES ANYONE HAVE THE GEARING CHART FOR SPEED AND RPM? I THOUGHT I SAW ONE ON HERE ABOUT A MONTH AGO. IF SOMEONE HAS IT COULD YOU PLEASE REPOST. THANX
Duey that chart is not even close to being right. Post your set-up - Gears, #of teeth on drivers and rpm and I'll give you speeds.
Discussion Starter #5
I AM WONDERING IF GEARING TO 23/40, 22/40 OR STOCK 22/41 IS BETTER FOR 1500' @ 7840 RPM'S I DO HAVE THE SPEEDWERX CLUTCH KIT IN. ALSO IF THERE IS A BETTER SETUP THAN THE SPEEDWERX? I HAVE A SET OF HEAVY HITTERS FROM MY ZR 800 I AM LOOKING TO TEST WITH ALSO. THANKS FOR ANY HELP!!
Hey Morrisond can you run a cuople of #s for me. 10 tooth driver, 8500 rpm, 20-39 gear. Also same set up but 20-40 gear.
Hey Duey, I'm running 73 gram weights and it rocks. Kick the SW kit on another sleds butt big time, 4 sleds in 600 feet. ;)
1 - 9 of 9 Posts
