I have never seen this before, after trailering home the other day I had gas leaking from my sled? Off the trailer and in to the garage and apart it came, I found that it was leaking out of one of the carbs, what would cause this? Its a 01 600 ProX, I did not and have never shut off the fuel before, I took the carbs off and cleaned and reinstalled and no leaks and runs fine, any input would be great thanks.
Well you could have had had a port that was blocked and it over filled with gas.
All it takes is a Little Spec of Crap between your Needle and Seat and that is going to
Happen. Floats Hanging up on the rod can do it also.
