If I dropped in a F7 EFI would I need a new gas tank on my 04 440 Sno Pro ? (I have a custom 10 gallon aluminum)
You would have to figure out how to mount the fuel pump as I doubt you can get into the aluminum one without cutting and welding.
With a alluminum tank you'll have to cut the top off and make it bigger or cut hole somewhere on the tank to get the pump inside of the tank to mount it. Find someone that can weld alluminum and it won't be a problem.
Can you mount it outside the tank??[/b]
No.
You'll have fuel all overt he sled before you've even fired it up.
Why?
Because the pressure regulator will let the excessive fuel out.
