Will the Fusion skis work on an edge?
<div align="right">index.php?act=findpost&pid=905389
The 06 Edges have the same ski as the 06 Fusion, if you compare dual runner to dual runner. The 1822808-070 dual runner ski is used (so far) on the 2006:
600 HO Fusion M10
700 Fusion M10
500 Classic
550 Classic
Trail Touring
600 Classic
600 Edge Touring
Installed on an Edge IFS you will need the 5412018 rubber stop.
The 1822881-070 single runner ski should also work on the Edge. The parts books do not yet show the internally tapped reinforcing shaft that ties together the upper portion of the plastic saddle just inches forward of the ski mounting bolt. It has to be loosened to mount the ski and removed to get at one of the skag mounting studs.
Brand loyal, not brand blind
600 HO Fusion M10
700 Fusion M10
500 Classic
550 Classic
Trail Touring
600 Classic
600 Edge Touring
<div align="right">index.php?act=findpost&pid=906904
short 1/2 inch socket on a extension {1/4 inch drive} gets that nut loose, fingers or 1/2 inch open end wrench finish's it. didn't take the cross shaft off. did it sunday.
