Just to be sure...In Michigan most of the fuel I see has 10% Ethanol mix.That would mean we should run on the Ethanol setting..Correct ?
If that is the case..Then fuel containing less that a 10% mix of Ethanol would mean running in the regular position ?
And to be safe..run in the Ethanol setting ?
I know these questions seem a bit repeatitive(or however it's spelled)...But hopefully someone will clear this up once and for all.......At least for now !
