What's the deal now with the Fuel Switch postion? The Coolant Bulletin States:
The pump I used to put gas(87 octane) in my sled said "with MTBE". I'm pretty sure from what I've read about NE there is less than 15% in this area. I've been running the switch in the Regular postion without a problem. So now what with this bulletin issued...run in ethanol all the time I guess to be safe?
It would be nice to get a direct answer, complete and detailed, from AC and be able to put this topic to rest and move on.
Did AC throw the10% ethanol and 15% MTBE pecentages out the window and now they are saying if contains either run the switch in the ethanol mode?C. Make sure the switch on the console is in the ethanol mode.
D. Use regular mode only when running non-ethanol or non-MTBE
gasolines.[/b]
