1 - 9 of 9 Posts
Thanks CJT,
I just measured the inside angles and they are running 6 degrees more than the outside!
Never even thought about it being differant between the two.[/b]
WOW 6*?? I have never measured the DD helixs,but the reverse cam(old helix) is two degrees different from in to out...the DD must be alot thicker to be 6*?
well I just found out that many manufactures use the centerline of the helix ramp so if we split the deferance that would put me at 3 degrees larger making the stock helix very close to advertised!
well I just found out that many manufactures use the centerline of the helix ramp so if we split the deferance that would put me at 3 degrees larger making the stock helix very close to advertised![/b]
Cool...It took me a while to figure out that one too!
Discussion Starter · #7 ·
BELOW IS THE ORIGINAL POST I DID AT ARCTICHAT
LOOKS LIKE I NEED TO ADD ABOUT 3 DEGREES TO MY NUMBER SINCE THE CENTER OF THE RAMP IS WHERE IT IS FIGUIRED AND I DID IT ON THE OUTSIDE ORIGINALY.
I have 7 helix's and would like to share what I have found about them.
I have the factory 44/40 compound cut (2 straight cut angles), MAG performance Dalton compound cut
and 5 EPI progressive cut (no straight angles) in 50/38, 50/36, 48/40, 48/38, & 46/38
After taking out the 48/38 EPI helix that was marked on the package I noticed it was not stamped on the helix like the others.
I began to question if it was the correct piece.
So I printed out on heavy photo style paper a 360 degree protractor.
I cut out right angles in the following degrees 36,38,40,42,44,48,50 & 52
I then wrapped the different sizes around the helix while sitting on a flat surface.
The straight compound angle helix's are pretty easy just use the angle that is parallel to the ramp.
Progressives are a little tougher because of no flat angles on the ramp, so what I did was mark the helix at the point the paper angle intersected the ramp.
I checked wear the pattern on the factory 44/40 helix then marked each helix where the roller sits when belt is at the most outer part of the sheaves (about 1 1/2" from the back or open end of helix).
I then noted the change of the compound angles on the factory helix's (point where it changes from 44 to 40) which was about
1 3/4" from the back or open end of the helix.
Finally I also guessed from wear marks, about how far the rollers were actually shifting out to last year.
This was about 2 3/4 from the back or open end of the helix.
OK now I started with the factory 44/40 and found that was really about 42/38 with the 38 more like 37.5
Now I am scratching my head, how can this be? I doubled checked the angles for correctness.
So I remembered that DONNO had the same MAG 2 helix I had and he came up with a 48/38.
I grab mine and check it, sure enough 48/38.
Now I am guessing that I am doing this correct judging by I had the same results as DONNO.
Next I check the unmarked 48/38 after struggling a little with the progressive style I came up with a 46/36.
Close but not what's marked on the box
The numbers that I am using for the first measured size (largest number) is 1.5" from the back or open end of the helix because this is where the rollers sit with no shift out.
Here is a final list of all the helix's with rated numbers and my measured numbers
------------Rated----- Measured------ Style
Factory--- 44/40------ 42/38--------- compound
Mag 2------- ?----------48/38--------- compound
EPI------- 48/38------- 45/36--------- progressive
EPI------- 48/40------- 46/38--------- progressive
EPI------- 46/38------- 44/36--------- progressive
EPI------- 50/38------- 44.5/36------- progressive
EPI------- 50/36------- 52/36---------- progressive
Below is pictures with each one that has been marked with the rated size, then I made marks for the different degrees.
I also made a RED mark at the top that shows where the rollers start at.
Then the BLUE mark is distance were the factory angle shifts at (this was just done for my own reference)
The bottom RED mark is about the farthest point were the rollers traveled to last year.
If I am incorrect in the way I have measured these helix's at least I would be incorrect on all of them and I will be able to make a good guess at my next change using these numbers.
I only paid $25 a piece for the EPI helix's brand new so I don't feel bad about the discrepancy of the numbers, just glad I laid them all out rather than just slapping them in according to the rated specs.
This is the factory 44/40 that looks like a 42/38 or less
[attachment=282654:clutch_mod_rkt_005.jpg]
wear marks on factory 44/40
[attachment=282655:clutch_mod_rkt_006.jpg]
Mag Performance looks like a 48/38
[attachment=282656:clutch_mod_rkt_004.jpg]
EPI 46/38 that looks like a 44/36
[attachment=282657:clutch_mod_rkt_007.jpg]
EPI 50/38 that looks like a 44.5/36
[attachment=282658:clutch_mod_rkt_008.jpg]
EPI 48/40 that looks like a 46/38
[attachment=282659:clutch_mod_rkt_009.jpg]
EPI 48/38 that looks like a 45/36
[attachment=282660:clutch_mod_rkt_010.jpg]
EPI 50/36 that looks like a 52/36
[attachment=282661:clutch_mod_rkt_011.jpg]
Discussion Starter · #9 ·
Here is my updated final measurments, I added 2 degrees to my outside helix measurement to come up with these and for the most part they do fall inline with the rating they were stamped with.
I included the factory split to compare the new helix to the factorys point of when it changes from the straight 44 degree point to the 40 degree portion. This was done to help predict the secondary reaction to the differant helix
Marked #------Measured------Starting #------Finish #------Factory split
48-38------------48-38-----------46.5------------38--------------44
48-40------------48-40-----------47--------------40--------------45
46-38------------46-38-----------45--------------38--------------44
50-38------------48-38-----------46--------------36--------------44
50-36------------54-36-----------52--------------36--------------50.5
MAG2------------50/38-----------50--------------40--------------50
factory
44/40------------44/40------------44--------------40
1 - 9 of 9 Posts
