anyone ever have there ignition coil go bad and what were there symptoms. my sled still runs but when you go to wide open it fouls plugs out. is it possable the secondary windings are cutting out???? :wall:
Discussion Starter · #2 ·
today i got the values for the ignition coil. primary should be .24 - .36 ohms. im at .4ohms. seems to be close enough to be ok. Tested secondary coil in spec. tested boots. in spec. NOW What?????? any ideas out there :russian_roulette:
today i got the values for the ignition coil. primary should be .24 - .36 ohms. im at .4ohms. seems to be close enough to be ok. Tested secondary coil in spec. tested boots. in spec. NOW What?????? any ideas out there :russian_roulette:[/b]
I have no idea what is going on but it seems that everyone with an f series is having some sort of issue with this, and if anyone figures it out let me know
