Has any one used the Fett Brother Single pipe on a 900 before? It how much HP can I gain and will it lose dependability?
If I remember correctly. You have a CPR clutch kit in your sled. Jeff at CPR sells the SLP single and has settings for your sled to work with the pipe.
Might be better idea to go that route! :beerchug:
give the boys at Fett bros. a call make sure you talk to dennis or dale they both are real helpful. i sent my shocks there this year and got one of there ride tech kits. good guys to talk to.
Originally posted by bly123@Oct 19 2005, 11:51 AM
Probably the CPR SLP Pipe might be the smarter way to go. Thanks!
<div align="right">index.php?act=findpost&pid=940405
The guys at Fett are nice but they are so against using pipes and other bolt on stuff. Why I dont know, maybe because they had bad luck in the past with other companies stuff??? Not everybody makes bad stuff.
<div align="right">index.php?act=findpost&pid=945497
Probbly because 75% of the people that buy that kind of stuff do not know how to use it properly and do just that. Bolt it on, and then call up bitching when they burned there motor down.
