I have been told that my throttle cable could be limiting my top end performance. How can adjust the slack/tension? Thanks for the help!
I had to adjust mine, very easy to check. Hold throttle flipper wide open (I hope I don't need to tell you to not have the sled running) and at the same time reach down to your throttle body see if you can get the throttle body to open up any more. Mine had over 1/4 inch of play in it. What you need to do is take up the slack by adjusting the cable by the throttle body. Just loosen both nuts(above and below the attachment site) and tighten the top one till you have, they say, a credit card clearance from throttle wide open and complete opening of the throttle body. Sorry, don't have any pictures, but you'll see. Make sure you tighten both nuts, top and bottom. Then, LET ER' RIP!
Discussion Starter #4
Thanks for the help guys. Seems to be a lot of play in my throttle. I can fit about 5 credit cards between the throttle & the bar. Your help is greatly appreciated!!
