i did the update myself the other day, and then i went up to houghton 10th -12th, i noticed that the sled smokes considerably more at idle, and loads up through low to midrange until i open up the throttles for awhile, kinda t's me off, i haven't checked the oil ratio yet, and i have no snow locally to do it, plus i just found a cracked pipe, so that will have to be changed also, but i was just wanted to see if others were seeing the same crap after having the update done?? thanks
I totally agree with you , i just got my back seems flat in the middle !!!!! the hard part would be convincing the dealer that there's a difference
mine is sputtering at take off...loading up! (after oil pump update) i wonder if BOSCH +4 plugs are avil. for these sleds?
