1 - 1 of 1 Posts
AC
On the F7's, why do you use a mechanical pump to ratio and inject the oil? There is already a computer onboard, use it as the brains instead of linkage. We have a TPS, I take it there is feedback for when the fuel injectors are firing....thats 2 ways of getting a fuel flow reading without adding anything to the sled. Add a servo motor or pulsation pump running off a modified ecu program to inject the oil and that should be it.
Even though the problem with oil ratio has just surfaced I've questioned why the mechanical pump was used since day one.
1 - 1 of 1 Posts
