1 - 7 of 7 Posts
What is the cylinder compression suppose to be, and what compression checks are you guys getting? I'll be doing mine tomorrow.
2014 XF800 137
Mine shows 147 on each side with a Sears compression tester.
i did bosssho's a couple of weeks ago this is how i did it .
ice cold motor
remove one plug at a time
wide open throttle
pulled just under 10 pulls
on a snap-on gauge 151 and 153 psi
Discussion Starter #5
Just did my compression check. If what you guys previously stated are the norm, I have some serious wearing happening.
Mag side- 125 psi
Clutch side- 135 psi
It could be your gage! You need a CLY. leak down tester! Compression gages dont tell you what you need to know! I just use a Compression gage to see if i have 0 or some Compression.
Skydog
actually a compression gauge works very well to let you know what the compression is at, the leakdown gauge tells you how much of the compression gets by the ring(s) over time.
there should not be more of a 5 lb difference between cyls in my opinion , but hey thats me. when you do the test you must hold the throttle wide open and the motor must be ice cold , dont run it at all before you do the test and its best to do it like 24 hours after a run period. also make sure you leave one plug in while testing the other cyl .
1 - 7 of 7 Posts
