I rotated the coil so the plug wires point to the bottom...rerouted the PTO side wire in front of the steering column and both wires if front of the coolant line as recomended.
One problem..The right side plug wire now rubs the steering rod.....Is there a better way to route the plug wire ? (need to be about 2" longer)
Any suggestions ?
I did mine today also-turned out great and it works-on my f5 not even close to steering arm-i take it you have a f7????can you ziptie it to something to keep it away?????
Bee...I probably could use a zip-tie...But the wire seems short.Did you install the coil back in its original position...with regard to the side facing the frame....I am sure I will figure something out!! Yes..F7 SNo Pro
