1 - 8 of 8 Posts
I just picked up a F6 and would like to know where is the tool box, there must not be one. The Ethanol switch, where is it? Electric Accesory? On my last 4 ZRs it was right behind the ignition. I need to hook up an electric shield. Where do I get power.
Thanks
there are 2 spots to hook up to power for the shield. one is behind the speedo and the other is behind the servo motor
yea for your heated shield there is a plug tucked down behind the servo motor. I think it has a brown and yellow wire. cant remember tho. You might have to pull your servo motor off.
I have the Early Release F6 and it has the Ethanol switch located on the dash. The Later 2004 - present models have a wire near the ECU.
Can someone can chime in and state whether it needs to be plugged in or not for regular fuel? :dunno:
1 - 8 of 8 Posts
