I was just looking under the hood of my F5 Sno Pro, and there are a bunch of small round oil spots all over the engine and surronding areas. The sled is running great. It seems to be using alot of oil, I've almost used up a gallon of oil (tank is almost full right now) in about 230 miles. I cannot see where it could be comming from. I checked the Chain Case, and it's still full.
I have a picture, but I fogot my USB cables for my camera at home, I'll post them when I get a chance.
Is this normal? Or is there something wrong? Any ideas? It looks like oil, but I'm not sure..
I know lots of us have had an exhaust leak, which makes a mess of things...usually around the clutch cover, carbs, etc. Some have been worse than others. Leaves a sticky, oily residue all over. :eek: If that's the problem, it will probably seal itself. As far as oil usage...my dealer starts looking into mine at 8:00 Monday morning. I am using waaaaaay too much oil too! :wacko:
We're probably getting about 400 -500 miles on 2.9 quarts of oil (Three tankfulls of gas).
Your using to much oil. Have it checked at the dealer.
I'm sure it's an exhaust leak. Should seal itself and it probably only does it when the motor's cold.
Cat S.
I had the same problem. Took off the pipe and put some ultra copper rtv around the donut where it seals on the pipe. Ran it and it still leaked. I took it off again and put some on the inside of the donut where it seals on the manifold- problem solved.
