If you are like me....I was checking the jets to see if they were the right size. While I had the carbs off I was looking at the lines... the small coolant line on the pto side going to the cylinder was rubbing on the bulk head.. it was a little worn with only 140 miles on.... so I checked the line going under the engine .... sure enough I felt an area where it was worn also.... it is Number 11 that is going under the engine... I couldn't find the part # for the coolant line going to the cylinder.
just something to look out for......
