I'm in need of some help..I went out on an 80 miles lil trip yesterday and I noticed at about 50 miles into the ride my oil light was comming on...and I had about half a tank of gas...this seems alil high to me...what are the things I can do to...lean it out....cause I'm pretty sure its causing my machine to not run as well as it should be...thanks an info would be great.... :)
I had the same thing occur. Used 1 gallon at 130 miles. Took it into the
dealer. He did the pump adjustment, said there is a "min" setting mark.
Has been good ever since, about 1 quart every 80 miles.
I was told by my dealer that I should get about 150 miles per qt. I'm getting right around 96 miles per Qt. and am hoping he'll get my pump set up to get the 150 miles per qt.!! It should run better at 150 per qt. because it'll be leaned out to where it should be. :ph34r:
Snoace and New_catowner,unless your riding in the mountains a WOT I think your both using Way too much oil for the mileage your stating
After I adjusted my pump, using 1 quart per 130 miles. Haven't checked the specific ratio but piston skirts look good and plugs show plenty of oil.
