1 - 2 of 2 Posts
I have a F-5, But my friend has a F-7 which just melted down. Talked to a dealer and this was his thoughts. P.S. he has no melt downs.
In the smart valve there is a rubber washer with a small hole held in with a spring. If this hole gets Swelled up the valve creates a lean spot. He has removed the small rubber washer on all his sled he sent out. He said might have something to do with the first tank of pre mix not duluted enough. Like dumping the oil onto the gas and hoping it mixes. this oil could also coat the fine screen on the smart valve also. Just a thought
1 - 2 of 2 Posts
