The carb slides on my standard F-5 are not opening all the way. They are about 1/4 of a inch from the top. Dealer said this is normal and not to touch. If they need adjusting what is the best way?
My sled hasn't used any oil yet.Originally posted by Wicked King@Sep 2 2003, 03:23 PM
Same here... because of all the slack in the throttle cable, the oil pump was engaging long before the carb slides. Like redF5sp said, you'll at least save $$$ on the oil! :div20:
Are you using a crazy amount of oil?If so, that is probably the problem!
