What is the optimal temp range I should be looking for on my gauges? I am installing a Digitron and was wondering what temp range I should be jetting for. Single Pipe, ported ,geared, xcsp 800 2002, vforce, high flow, air box mod.
Temp will be somewhere between 1100 to 1300.
You must determine what temp is good for your engine. To many variables between sleds. Gearing, fuel, timing, plug type, can all change temp.
Put a piece of duct tape on the guage. Tune your sled reading plugs and wash. When its right, then take tape off and see your temp.
There is no temp that someone can tell you that is right for your sled. You must determine it yourself.
