i have an 03 f7 and live in nh. most of our gas here is a 10% ethanol blend. i was wondering if it would be ok to run 87 with the switch on ethanol or what i should do ? thanks
not sure if you have to run the switch on with just 10%? but it is OK all it does is give you 3% more fuel, you need more fuel when running ethanol or it will be to lean.i have an 03 f7 and live in nh. most of our gas here is a 10% ethanol blend. i was wondering if it would be ok to run 87 with the switch on ethanol or what i should do ? thanks[/b]
