I am just wondering how much power the Arctic Cat temperate guage and heated shield draw while both are working. I see in the performance manual that if you draw more than 4 amps extra the computer will go into limp mode. If I run with the guage, shield and handwarmers on high would it be enough to make this happen? How can I test to see how much power the above are drawing?
I don't have the gauge, but I run my heated shield and hand and thumb warmers on high often (cold winter) and I haven't seen a problem..
the gauge takes only like 10 watts to run. dont worry about it. the gauge has a really small light bulb. and the gauge itself takes very little.
Bottom line- dont worry about it. unless you start adding more high draw components.
I did put a temp gauge in my sled and also run the heated sheild along with the hand ,thumb warmers on high and had no problems at all. Temp guage is great to have also. B) B)
