1 - 9 of 9 Posts
Does anyone know if there is a hookup anywhere on the sled , behind dash or...., for an electric face shield? Thanks
Super Moderator
on some F7's its hard to see but it is there buried behind the servo motor. Yellow and brown wires going to the connector..
yea its just down from the ignition, take of the plastic cap covering the servo motor, take out the 2 screws to take out the servo motor and its behind it, almost burried.... but its an actual connector!! Get the correct plug in and.. plug in, hehehe
put back together
this site rocks!
Yeah, the one near the servo is the best. The one near the speedo/tach doesn't seem to have enough power. Also, its a pain when you open your hood because your plug will go up with it. On my sled the one near the servo was very easily accesible (without taking the servo off its brackets). But on my brother-in-law's we had to take off the servo to get to it.
If you own a HJC helmet you need a RCA jack. Try Radio Shack or buy a Ski-Doo jack and cut the End off with the connector. Also buy the Accessory adapter from cat, plug it into the plug by the fire wall the extension is nice to work on. Use automotive 18ga. Connectors and connect to the yellow and brown loops on the accessory harnes.
Happy Sledding!
Thaigon :ph34r:
1 - 9 of 9 Posts
