Has anyone on here used Hot Rod efi chips from black Magic if so did you see any mileage gains also list any other mods you did to your motor with the BM chip
2014 XF800 137
Has anyone on here used Hot Rod efi chips from black Magic if so did you see any mileage gains also list any other mods you did to your motor with the BM chip[/b]
Had one in my 98 600 efi, gave it a low end bog, ended up getting the new style AC chip which deleted the blip-throttle-mode, much better.
You are better off putting in a fuel reducer, if I remember right it is 36.2 @ WOT.
Where would we get a fuel reducer from?. Also, what did the new style chip you put in do for your sled?
Rob
36.2 SEAMS low factory spec is 37.9 + OR - 2.2
2014 XF800 137
36.2 SEAMS low factory spec is 37.9 + OR - 2.2[/b]
You could be right, I may be thinking of a different model that I had an efi buddy on.
