1 - 8 of 8 Posts
has anyone ever drilled out there stock fishbone running board things and sanded them down , painted them , and then rivited them back on ? if so how did it turn out and how long did the paint actually last ? :cn:
i was wondering the same thing and gave up after i looked at the rivets. if you deciede to go through with it, get them powdercoated. it will only cost about $15-$20 each.
You can order powder coated to match right thru Polaris. The rivets are # 7661367 tubular rivet, not expensive unless you dont have the tools to put them on correctly
5133971-067 rh side
5133972-067 lh side (067 is the color code for black)
We took them off my son's prox2 to change the color and let me tell you , that factory powder coat is tough ! It would not come off with our bead blaster at work , we ended up sand blasting with corse abrasive then bead blasting the bare aluminum to smooth out the finish.
1 - 8 of 8 Posts
