Have to remember, this is a FireCat. Remove the secondary so you can get at the voltage regulator. Once the voltage regulator is off, the bearing should slide right off, key word should.
Banned
All Firecats have the pto side bearings pressed on the drive shaft and jack shaft. The chaincase bearings will slide off the shaft.
Krom
