when i changed my gears i put my sled on its side with the oil real full to make sure i would not get any air in the line i then took the bolts out and the cover took some getting of i took the track and moved i back and forth alittle and my gears came out with the cover
i replace the bearing and checked seals then put my 60/60 gears in with the cover i found it easy to put the gears and bearing in the cover and set the hole thing in then dont forget oil 3 oz and bd sealent
this is what i have found works good and i have swaped gears about 4 times
