What are people doing with the support bracket for the pipe that is welded to the stock y pipe? Cutting it and re welding it to the new y pipe or just taking it out completely?
I used the mount that came with my D&D ypipe. I might still weld the old ball setup back onto the new ypipe though, not sure yet
i'm a fan of cutting it off and rewelding. works great on a 03-04 style pipe. otherwise your heat shield gets all beat up and i don't like the tab they send you to attach the spring to. the spring they give you breaks right away too. you could use both but i would at least reweld the ball mount.
