I have installed the power authority kit but i want to know how you can adjust it because the pressure of the guage wont move it stays in the same spot. Please help
The turning of the screw only changes pressure at WOT. Best to do while riding. Now take the screw and screw in till it bottoms out. Back it out 2 full turns and one half turn. Start sled and look at the gauge. The difference between idle and WOT is 4 psi drop for trail safe and 6 psi for short drags. Learn how to read plugs and piston wash as these drops can vary from sled to sled.
I beleve you have to run sled wfo for 100 ft to get baseline on fuel press,then start turning in I think 2/1/2turns out is starting point, I would not go any less the one turn out, hope this helps
