1. Can I add the second idler found on the SRX to my 2018? Direct bolt on?
2. Can I buy the rear axle and wheels found on the SRX to eliminate my tri-hub? I'd rather do this than a an aftermarket kit because I like the look of the SRX wheel.
Not sure about the idlers but I did try the wheel replacement. Didn’t work due to the shaft would not go through the rails. The slot in the rails of the 18s is only big enough for a bolt.
