Advisory No: SAS313 Subject: Pre-Delivery Cooling System Bleeding
Affected Models:
All 2003 Firecat 500 cc and 700 cc Models
It has come to our attention that the cooling system on the affected
models
may develop an air bubble in the cooling system if the cooling system
has
not been properly bled. To ensure that an air bubble does not exist or
develop in the cooling system, Arctic Cat strongly advises all
dealers to
bleed the cooling system according to the procedure included in this
advisory.
If you have sold an affected snowmobile, please contact the owner
regarding
this issue.
NOTE: Be sure to have the identified pre-delivery work completed
before
allowing an owner to take possession of the affected snowmobile.
NOTE: Be sure to inform the customer to 1.) use up one full tank of
pre-mix, 2.) drive slowly during the break-in period, 3.) monitor the
coolant level and coolant temperatures, 4.) make sure there isn't air
in
the oil line.
Bleeding the Cooling System
NOTE: Prior to bleeding the cooling system, make sure the following
pre-preparations are completed.
A. Make sure there is 100:1 mixed gas in the tank.
B. Make sure that there is no air bubble in the oil line.
C. Make sure the switch on the console is in the ethanol mode.
D. Use regular mode only when running non-ethanol or non-MTBE
gasolines.
1. Check the coolant level in the clear coolant bottle on the
right-hand
side of the snowmobile.
2. If the coolant level is low, fill w/coolant.
3. Because the coolant fills slowly into the engine, it is necessary
to
wait for 10 minutes after filling the coolant tank to allow the
engine to
fill with coolant.
4. Recheck the coolant bottle level. If the level is low after 10
minutes,
repeat steps 2 and 3.
5. Install the coolant cap to the "first" position.
6. Start the engine. Do not exceed 3000 RPM.
7. After the engine has run for about 3-5 minutes, the right-side
running
board heat exchanger should feel warm to the touch.
NOTE: This is a sign that the thermostat has opened.
8. Shut off the engine.
9. Tighten the coolant cap to the "second" position.
10. Tip the snowmobile onto the left-hand side (PTO-side) to allow
air to
move from the rear heat exchanger to the coolant tank.
11. Recheck the coolant level. If the coolant level is low, repeat
steps 2
and 3.
12. Install the coolant cap to the "first" position.
13. Place the snowmobile onto a safety stand.
14. Start the engine and run for 1 to 2 minutes. Do not exceed 5000
RPM.
15. Monitor the heat exchanger temperature by touch.
16. Shut the engine off for 5 minutes.
17. Start the engine and repeat steps 7-16 an additional 2-3 times.
Thank you for your cooperation in this matter.
Sincerely,
Product Service Department
Arctic Cat Inc.
Affected Models:
models
has
dealers to
advisory.
regarding
this issue.
before
in
the oil line.
gasolines.
right-hand
to
engine to
fill with coolant.
minutes,
running
air to
steps 2
and 3.
RPM.
Sincerely,
Arctic Cat Inc.
